1967 442
ordered a set of #5389 142 lbs to replace my #5385 168 lbs that sat to high and wheel hop. #6321 were to soft at 119 lbs i would think.
Sorry pal I didn't notice this thread till just now. Not sure if this helps and obviously its a little late but here goes.
http://www.oldsmobility.com/old/imag...hics/mmp19.jpg
great thank you so much. if am reading it right its a part # 9787050 that comes out to 122 lbs. or is it #9787048 for the 4-speed ?
This list verifies. http://www.oldsmobility.com/mpc/group7000/text04.htm
Looks like 140 lbs is factory HD. Post 12 in this thread, https://classicoldsmobile.com/forums...springs-40898/
#5385 has the reputation you experienced. Post 4 same thread above.
This thread may also be of interest to you, particularly post 15. https://classicoldsmobile.com/forums...springs-36321/
P.S. here is QA1 spring rate information. 1964-1972 GM A-body
Soft is 130, Medium is 150, Firm is 175, https://www.qa1.net/assets/uploads/d...le-Weights.pdf
the 5389 is 12.6 free height. 142 - 737 - 7.5 installed height .554 coil size. getting them from springs&things, someone is making them again. should lower the height 5/8" to 3/4" over the 5385. let you know next week.
hope to get the back down a little
wow what a difference, better ride, better handling and no more wheel hop. it lower it 5/8 of an inch. i will get another photo in same parking spot. wouldn't want it any lower.
