1966 442 - new carpet intall question
Good morning! I am about to replace the carpet in my '66 442 and wanted to know the best way to remove both bucket seats without killing myself.
Thanks!
Jon
Thanks!
Jon
Let it set in the Sun and or the Heat for a few days.Use the tip of a Soldering Iron to cut the holes for you Mounting Studs and Seat Belt Holes.It will seal the Holes .Most Carpet sets are Olefin which is nothing more than Plastic,,Using the Soldering Iron will prevent the Carpet from Runs .
Remove front mounting nuts FIRST. Then release the seat adjuster and slide the bucket seats full forward and remove the rear mounting bolt and nut. Then lift the seat.
Carpet install.
Joe, hate to bother you about this but I am getting close to carpet. I have a problem following this path if I have a console. I would appreciate your thoughts on this.
Wayne
What kind of problem? This is how the cars were built. Install the seats, install the carpet, then install the console.
