1964 A-Body Convertible Frame
Sorry to squeeze this in, but I'm not getting any answers at all from the Buick forum. As well as my 65 Oldsmobiles, I've got a 64 Skylark rag with a rotten frame. Will anyone tell me what year frames are compatable, and will any A-body rag-top frame work?
Thanks Gene,
I want to keep my options open. Even though a smart man would wreck this car, and sell the bits, I hate to go that route unless I absolutely have to. Few enough of these old rag-tops left. Hate to lose another one.
Dave
Dave
Frame Choices
I appreciate the response, Henry.
Would prefer no cutting or welding if I swap frames. Very few Pontiac Lemans from mid sixties where I live. Likely I'm looking at using another A-body Buick frame, or repair the one it's on. Too bad I can't use a 65 Olds F-85 sedan frame. I've got a decent one here. Looks like it would be huge work to box it in. They don't even have the tranny cross member brackets in the same place. Brackets are on the inside of the boxed sections. I think the rag-top cross member is shorter by maybe 4-6 inches.
Think I'll go back under and hammer the frame some more. Maybe if I use a lighter hammer the frame will sound better LOL.
Dave
Dave
It is possible to cut out the boxed sides(if not rotted) of the convert frame and transfer to your sedan frame.
64-66 ElCamino frame is boxed but longer at the end due to the bed, can be adapted by shortening behind the rear axle. Might be able to find an ElCo in your area?
Henry
Henry
It's mostly the driver's side that's really bad. Whole bottom is soft. Also bad left frame beside the gas tank. Passenger side has a 6 inch hole toward the rear of the main side rail, but the rest of the right side is pretty solid. Think I'll take another look and see how solid the sides of the frame are. Not sure if the body would sit properly on a 65 F85 frame or if there's extra cutting and welding to accommodate bumpers or body mounts. Interesting dilemma.
As for 64-66 El Camino, there aren't too many, and they are quite desireable.
Dave
Dave
The sedan frame will directly interchange with the convert frame, just does not have the boxing.
The convert inside frame rail boxing will transfer to the sedan frame, it's just an add on piece. Henry
You don't happen to know if the rad support will work from 65 F85 to 64 Skylark, do you? The bottoms are a slightly different shape. Also wondering if the Skylark headlight assemblies would bolt on the F85 support correctly. What a dog's breakfast !!
Dave
Dave
I have a 64 olds. 88 convertible frame. Larry 979 7771160
oldspackrat
December 21st, 2012 08:27 PM
oldsmobilty
September 27th, 2012 04:26 PM
sixty9olds
June 14th, 2011 06:43 PM
1969goatman
August 30th, 2010 07:44 PM
