Fuel gauge/tell tale help
Old May 24th, 2014, 07:21 AM
65dynamic's Avatar
I'm in need of some help to diagnose my fuel gauge. I've read some other threads but haven't found any that have my symptoms. My gauge is stuck at 1/4 tank and doesn't seem to be getting any power to the gauge. The dash lights on my other gauges are working fine, but are not working on the fuel gauge. None of my tell tale lights are coming on either. I pulled the bulbs and they're ok. I'm suspecting the resistor on the back of the gauge may have gone bad? Any ideas?
65dynamic is offline
Old May 24th, 2014, 07:45 AM
The resistor has nothing to do with the telltale lights. If a bunch of dash electrical items in the same general area are not working, the number one cause is a bad ground. Verify that the ground strap from that pod to the metal cowl is in place, or run one if in doubt.
joe_padavano is offline
Old May 24th, 2014, 07:48 AM
65dynamic's Avatar
Thanks for the tip, I'll see if I can trace the ground from the harness.
Old May 24th, 2014, 07:56 AM
Keep in mind that the ground path might be a sheet metal strap, not a wire.
Old May 24th, 2014, 08:00 AM
The gauge has 12v connected to it at all times. The sender side, is a variable resistor connected to ground.
Have you done anything to the wiring? If you disconnect the wire from the gauge to the sender with the key on, the gauge should go past F. Grounding it, the gauge go to E. If neither happens then move to the gauge and repeat the test.
Fyi, I believe your sender is 0-30 ohms.
oldcutlass is offline
Old May 24th, 2014, 08:01 AM
65dynamic's Avatar
Will do. I didn't see a strap on it when I was under there. Would it make sense to run a ground wire from one of the mounting tabs/bolts on the back to a ground?
Old May 25th, 2014, 11:32 AM
65dynamic's Avatar
Thanks for the help fellas. It did turn out to be a ground that was not hooked up under the steering column. Funny enough I actually have about a 1/4 tank of gas in there. Lights on the gauge are working too.
Old July 21st, 2014, 07:26 AM
dprestia's Avatar
taking this a step further...
Would a bad or missing ground also be the likely cause of the speedo and clock not functioning? I have a 1967 Olds 98 LS and for some reason the day i bought the car all the gauges stopped working (yet the lights still come on with the headlights).
Thanks in advance
dprestia is offline
Old July 21st, 2014, 10:21 AM
Speedo - no its a cable driven gauge. Clock - possibly and it can also be dirty.
JPMDaddy
January 31st, 2020 04:01 AM
F-85_1964
February 21st, 2013 06:02 PM
jon69olds
September 12th, 2012 06:31 PM
VikingBlue
August 1st, 2012 02:49 PM
Lady72nRob71
January 19th, 2010 10:35 AM
Quick Reply: Fuel gauge/tell tale help
