Troubleshooting a points ignition
Old October 23rd, 2017, 10:49 PM
  #41
Phantom Phixer
Charlie Jones's Avatar
While points are still relatively inexpensive, I recommend an inspection and recalibrate rather than replace every year. When I run points I do no parts tuneups twice a year and replace them when I feel they are no longer serviceable.
Good advice if you live in dry , toasty , Texas .
However , in the cold , wet , climes of the north , the points can corrode enough over winter to make them useless .
My advice still stands .
Charlie Jones is offline
Old October 24th, 2017, 06:37 AM
  #42
Originally Posted by Supreme455
... it is parked nose in first and it can't be rolled out...
I always back in to a garage when I'm storing an old car, that way I can pull or replace the battery, fill up the float bowl, and mess with the ignition if I need to whenever I finally get back to it. Even if it's difficult, it's a good practice.
... the condenser looks prehistoric and I guess when I installed that coil years ago I used the same condenser.
Condensers seldom go bad, so that probably doesn't matter.
You can test it functionally if you follow the procedure at the top of the thread.
I don't know the name of that part under the rotator but it is a pain in the *** in the way metal thing.
It's the centrifugal advance.
So I bring a file with me for the points and when I open it up......yeah they look burned.
And the file did nothing to the contact that you can see looking at the points.
The points can be good and look bad, or be bad and look good.
It doesn't matter what they look like, and, be honest, you can't really see them in there anyway.
The point of the procedure at the top of the thread is that it allows you to test the points with minimal tools to see whether they are good or bad.
Most good ol' dwell meters also have a setting to measure points quality - you could use that pretty easily as well.
MDchanic is online now
MudEye
July 14th, 2014 04:41 PM
Alex72cutty
February 4th, 2013 09:41 PM
Olds Dad
August 15th, 2012 11:38 PM
damalden
July 11th, 2012 04:31 PM
442Dave
January 7th, 2012 07:28 AM
Quick Reply: Troubleshooting a points ignition
