MSD Ready to run
Old May 25th, 2013, 02:54 PM
Beer Connoisseur
70cutty's Avatar
MSD Ready to run
I am trying to install MSD Ready to run distributor to replace the points dist. I am a little confused. After reading numerous threads about hooking up HEI couple of things are still not clear to me.
I ran a 12 gauge wire from the pink wire under the dash, which gives me full 12v when ignition is on, to the distributor.
Do I keep the existing wires that are hooked up to the coil and run full 12v directly to the distributor or do I run a full 12v to the coil and then hook up distributor to the coil like in MSD instructions?
I have NGK Iridium spark plugs, how much should I gap them?
I've read anything from .040 to .060 so I am not sure.
Please help. Thank you.
70cutty is offline
Old May 25th, 2013, 03:15 PM
Orange is to the coil (-) terminal.
Red is to the +12V source and to the coil (+) terminal.
Black is to ground.
Hook the +12V wire to the coil (+), and the Red wire to the coil (+).
Source
MDchanic is offline
Old May 25th, 2013, 03:25 PM
There should have been 2 wires on your old coil. One was the resistor wire, the other was from the starter to provide 12v while in the start mode. The resistor wire I would just cap and stow. The wire from the starter in some cases is needed as the start and run circuits are isolated by the ignition switch, so you may need to connect it to the "batt" terminal on the HEI.
I gap my plugs at .045, but you can go as big as .060, the bigger the gap the hotter the spark.
oldcutlass is offline
Old May 29th, 2013, 08:26 PM
Beer Connoisseur
70cutty's Avatar
Thanks guys. I am gonna install it this weekend.
70cutty is offline
Old May 29th, 2013, 08:43 PM
Let us know how you make out. By the way you need to set your timing a bit different because of the advance curve on the HEI. Your engine may want more initial advance. Also watch the for pinging when you connect your vacuum advance.
Do you have a dial type timing light?
Old May 29th, 2013, 09:23 PM
Beer Connoisseur
70cutty's Avatar
Yes I just bought one. What should I set initial advance at?
70cutty is offline
Old May 30th, 2013, 03:54 PM
Beer Connoisseur
70cutty's Avatar
What do you mean it's not a HEI distributor??
70cutty is offline
Old May 31st, 2013, 04:48 AM
Beer Connoisseur
70cutty's Avatar
Originally Posted by ah64pilot
1. Did you buy it new?
2. What is the part number?
3. Does it have instructions?
Yes it's brand new.
MSD 8529
Yes
70cutty is offline
Old May 31st, 2013, 09:19 PM
Beer Connoisseur
70cutty's Avatar
So I don't need this wire for full +12V, just hook up to the coil the way it is?
70cutty is offline
Old June 2nd, 2013, 07:21 PM
Beer Connoisseur
70cutty's Avatar
Should I hook up the full +12V wire to the coil or just install it like points distributor??
70cutty is offline
Old June 2nd, 2013, 07:44 PM
dc2x4drvr's Avatar
12v to the coil.
dc2x4drvr is offline
Old June 2nd, 2013, 07:51 PM
Beer Connoisseur
70cutty's Avatar
Thank you.
70cutty is offline
Old May 29th, 2018, 10:42 AM
Rocketman!442's Avatar
Rocketman!442 is offline
Old May 29th, 2018, 10:43 AM
12 BTD initial, 36 total all in by 3400. I think I used the two light blue springs.
Old July 27th, 2018, 09:08 PM
Gone Johnson's Avatar
Here's a related question:
The MSD coil (MSD Blaster 2) that goes with this distributor, has an option WITH ballast resistor, or WITHOUT ballast resistor. My setup is already HEI (1972 Olds Cutlass w/350/350, 1977 GM HEI already installed), so, its just one 12V wire from IGN on fuse box, to HEI. Do I even need the ballast resistor with my setup?
Gone Johnson is offline
Old July 28th, 2018, 06:08 AM
This is what it should look liken no ballast resistor:
Instruction sheet
http://documents.msdperformance.com/8529.pdf
Old July 28th, 2018, 11:38 AM
Okay great, no ballast resistor. Got it yay, I get to save myself 6 or 7 Bucks!
Old March 26th, 2019, 09:19 PM
Thanks Gone Johnson, Ive never had so much power than since I installed this distributor. What a smooth running engine!!
Old March 26th, 2019, 09:38 PM
Awesome
Old March 26th, 2019, 09:50 PM
Awesome
Thanks oldcutlass, the help was invaluable
rick442
June 11th, 2018 12:20 PM
442Dave
January 7th, 2012 07:28 AM
slowolds
July 16th, 2011 09:15 PM
mp71conv
October 21st, 2007 10:49 AM
J'ville
June 10th, 2006 03:13 PM
Quick Reply: MSD Ready to run
