High Output Alternator??
Old September 17th, 2012, 06:31 PM
travisbeamon's Avatar
I'm trying to find a high output alternator for my 1972 Cutlass Supreme but I'm having trouble. Does anyone know a decent brand that makes high output alternators for 72 Supremes?
travisbeamon is offline
Old September 17th, 2012, 07:01 PM
brown7373's Avatar
How do you define a "high output" alternator? How many amps is your original and how many amps do you want?
brown7373 is offline
Old September 17th, 2012, 07:13 PM
Nufo's Avatar
give these guys a look...
http://www.powermastermotorsports.com/
Nufo is offline
Old September 17th, 2012, 07:22 PM
Just the facts...
BILL DEMMER's Avatar
i have 105 amp cs130's that are olds mount ready, minor wiring mods needed. search in parts for sale.
bill
BILL DEMMER is offline
Old September 17th, 2012, 09:10 PM
GM is a good brand...
Define what output you need. 78 amp 12SI alternators were factory installed on 307s in the 1980s and bolt onto your motor. If you need more, I buy 105 amp CS130 alternators from full size GMs with the 3800 motor (Bonneville, Eighty Eight, etc) at the wrecking yard for $15. These have the correct mounting bosses to bolt to your existing brackets. Just swap the serpentine pulley for a v-belt pulley. Google "CS130 wiring" for the connections.
joe_padavano is online now
Old September 17th, 2012, 09:22 PM
Aceshigh's Avatar
I go through a guy who rebuilds and resells high output alternators on Ebay.
He's got minimum overhead and charges very cheap prices and will custom
make it to your size, clock position, and belt style needs. I put in a CS130 140amp
chromed alternator from him for just $140, but I'm using a Taurus electric fan
plus an amp'd stereo system.
http://myworld.ebay.com/billh6800&ss...84.m1543.l2533
Aceshigh is offline
Old September 18th, 2012, 07:51 AM
455man's Avatar
I bought a CS130 for an '89 Pontiac Safari. It has the correct v groove pulley and mounts right up.
455man is offline
Old September 19th, 2012, 10:27 AM
Intragration's Avatar
It may be a silly question, but do you NEED a higher output alternator? Just wondering.
Intragration is offline
Old September 19th, 2012, 02:49 PM
stellar's Avatar
I have a 105 amp alternator for the external regulator style 10 DN if that is what you need. It is a bolt on with no wiring changes needed. I think yours may be the external regulator type.
stellar is online now
Old March 5th, 2013, 10:42 AM
ddd777's Avatar
Question
Is there any reason to have more than 63 AMPS for a stock 1972 CS - even with A/C?
ddd777 is offline
Old March 5th, 2013, 10:47 AM
ddd777's Avatar
never mind.
found this thread that expands on the topic:
https://classicoldsmobile.com/forums...ator-72-a.html
ddd777 is offline
cfair
April 29th, 2014 09:19 AM
bobfo1
June 18th, 2012 04:37 PM
yeahbuddy
March 6th, 2012 04:22 AM
geckonz08
March 17th, 2010 04:50 PM
drewt
March 16th, 2010 07:18 PM
Quick Reply: High Output Alternator??
