1971 Wiring diagram
1971 Wiring diagram
Does anyone have a digital copy of a 1971 F-85/Cutlass 442 wiring diagram and schematic? I went on wildaboutcars and downloaded it but it is blurry and hard to read the print. I would greatly appreciate it and put in my prayers to the hot rod gods.
Or maybe answer this question I have a good copy of 1969 that I bought from ironworks but am not sure if the harnesses are the same.
did you ever get a response to this? I need the same thing. Was just on here looking. I'm upgrading to newer alternator, HEI, and just cleaning up the engine area in general. I know what to change on the first things, but there is stuff I'm inclear of on this car. Plus I want to change a little bit of stuff on the inside to suit me.
You both need this:
http://www.ebay.com/itm/1971-OLDSMOB...a7cf52&vxp=mtr
It's worth every dime you spend on it. Wiring diagrams in particular are highly-detailed, fine-print things that are difficult to capture digitally.
For reference, the 1971 wiring diagram is located here...
1971 Original GM Oldsmobile CSM Wiring Diagram A Body "V-8"
Vintage Chief
June 20th, 2020 01:52 PM
