Tach reading high
Old April 15th, 2012, 11:23 PM
Magna86's Avatar
Tach reading high
Ok finally found a tach I like and wired it in today. First off it looks great minus the red illumination. Hope I can fix that. Problem I have is it reading 200-400rpm higher than what my digital timing light says. Everything is all good and snug. Its wired direct to tach on hei distributor was I supposed to have a resistor inline? Any help be great.
Magna86 is offline
Old April 16th, 2012, 01:23 AM
garys 68's Avatar
No ballast resistor on HEI. Bad spark plugs, wires, disributor cap can cause high readings.
garys 68 is offline
Old April 16th, 2012, 04:50 AM
Past Administrator
Oldsguy's Avatar
Finally, if it is an older unit that you bought from someone else used then it might need an adjustment. If there is no stop, does the needle read zero when the engine isn't running or does it drop lower than zero. If the reference is lower than zero then your error will be off by that much. Some tachs have an adjustment for that. Just a thought.........
Oldsguy is offline
Old April 16th, 2012, 05:59 AM
Magna86's Avatar
Sorry the cap/plugs/rotor/wires/coil/module and wires are new. Tach was new in box. Only adjustment was choosing which cyl/pulse setting. Tach reads 0 when not running.
Magna86 is offline
Old April 16th, 2012, 01:47 PM
allyolds68's Avatar
If you search here there a a few posts about repro tachs not reading correctly and a few posts on how to fix it (not that you should have to with a new one )
https://classicoldsmobile.com/forums...ation-how.html
allyolds68 is offline
RAMBOW
May 3rd, 2022 04:25 PM
HitTheHole
November 18th, 2013 02:46 PM
starfire
September 10th, 2013 08:43 PM
smcurro
Paint
January 29th, 2012 02:31 PM
MN71W30
June 8th, 2011 12:13 PM
Quick Reply: Tach reading high
