Wiring a '66 Cutlass Conv.
Hey all, I have been having issues with my electrical system from left turn signals (front and rear) not blinking but right side does, to brittle breaking wires. To avoid an electrical short or worse, a fire, is re-wiring the car a project for a novice, or am I going to need professional help? I would like to start with the engine/lights harnesses and "Painless" is the only company I have found that might work. I think it is a universal, but from past experience, universal doesn't always fit the way they say it will, and they are pretty pricey.
Any info would be helpful. Thank you.
You might want to try M&H Electric unless you already have
http://www.wiringharness.com/
or American Autowire
http://www.americanautowire.com/
Thank you both for the info. Now for the second part of my question... is this a job I can do myself or will I need a professional? I know very little about auto wiring, but if it was as simple as unplug old harness "A" and plug in new harness "A"... I would give it a shot. I know some wiring has been modified and/or bypassed over the years, so I can see how it could become puzzling at some point. Just thought I would ask.
If you have a digital camera take a lot of pics. Maybe I'm just feeble minded, but a day later I find myself wondering "did this go over/under/behind that?" Especially under the dash, where running it correctly means the difference between everything fitting or not.
If by "rewire" you actually mean "replace the harness with a repro", that's very easy to do so long as you take good notes or digital photos of how everything connects. You'll be time and money ahead if you start with a quality reproduction harness and not a one-size-fits-none "painful" harness.
blackjack_53
July 2nd, 2013 05:28 PM
Flgaurban06
Cars Wanted
September 21st, 2012 06:36 AM
oldzy
September 10th, 2009 05:23 AM
