Electric carb hook up and AC compressor hook up
Hello all,
I'm trying to figure out where do i Hook the positive wire that hooks up to the positive on the carb?
Also, Where does the positive wire from the AC compressor hook up to?
Thank you guys in advance for the help.
Any switched positive wire under the hood will work for the carb - might need a testlight.
Should be a 1"w plastic connector, with 2 wires in it, [green + black?] that plugs into the 2 prongs on the compressor floating around that side of the engine compartment.
Believe it came from the fenderwell and had something else to it that went to the engine.
ROCKET VAPOR
June 4th, 2010 09:47 AM
