Audio Expert
Old May 13th, 2011, 08:14 AM
501Paratrooper's Avatar
Audio Expert
Will the metal covering this small portion of the speaker interfere with the sound quality?
I really don't want to cut the metal if at all possible.
501Paratrooper is offline
Old May 13th, 2011, 07:59 PM
jo75olds's Avatar
Was there a picture ment to be included? Just FYI unless its a Subwoofer, anything covering any part of the dome/tweeter will interfeer with sound, if the metal is low enough, and you blast the speaker, the doam my hit the metal causing perminate damage. But I can't tell you if its in danger without seeing a pic.
jo75olds is offline
Old May 14th, 2011, 05:46 AM
Duh..I forogot the picture.
Here it is and thanks.
Old May 14th, 2011, 06:44 AM
Well, you've got one tweeter completely blocked, so you won't hear that one at all.
How important that is to you, compared to cutting bits off the car, is up to you. I'd listen to it as is and decide whether the sound is good enough that way before making any decisions.
You might consider a speaker system that puts the midrange and tweeters in different places, to get around this problem.
MDchanic is offline
Old May 14th, 2011, 06:49 AM
Thanks, I guess I'll cut.....
Old May 14th, 2011, 06:52 AM
extreme1's Avatar
Given that both the "tweeters" on that speaker produce the same frequency, you really aren't losing much. Make sure the speaker is spaced enough away from the deck that under full excursion it's not hitting the metal and you should be ok.
What are you putting over top of the rear deck? make sure it's got some sort of opening or you may as well not have put speakers there at all.
extreme1 is offline
Old May 14th, 2011, 06:53 AM
I'm getting the package tray w/cut outs.
Old May 14th, 2011, 06:54 AM
Are you sure that they are?
I've had similar 6x9 speakers in the past with two tweeters, each of which works in a different range.
MDchanic is offline
Old May 14th, 2011, 06:56 AM
I'm not sure if they are same range or not. They are from retro sound.
Old May 14th, 2011, 06:59 AM
Even if the two tweeters are identical and are crossed over for the the same frequencies, covering one will reduce that range by about 50% (maybe 40%), which will affect the sound. If your speakers had an adjustable crossover (unlikely), you could turn them up to compensate, but then you would risk overdriving them on loud passages and ruining the sound that way.
MDchanic is offline
Old May 14th, 2011, 08:30 AM
coltsneckbob's Avatar
Drill new holes and move the speaker over a little bit.
coltsneckbob is offline
Old May 14th, 2011, 06:26 PM
extreme1's Avatar
quite sure, they don't have separate crossovers for each tweeter.
if you are concerned maybe clear a bit of metal out from above the tweeter, or just make a proper 6x9 hole.
extreme1 is offline
1957 Super 88
June 4th, 2013 05:43 PM
auto_editor
January 30th, 2013 11:02 AM
White_Knuckles
November 4th, 2012 12:47 PM
Lady72nRob71
August 5th, 2012 08:09 AM
boondocker
August 3rd, 2011 05:40 AM
Quick Reply: Audio Expert
