Best way to shorten wires...
Old May 2nd, 2011, 08:17 AM
defiant1's Avatar
Question Best way to shorten wires...
Other than by cutting them . Since I am moving my alternator from the passenger side to the drivers side I will have over a foot of wires I will not need.
What is the best way to shorten them? In the case of the plug that goes in the alternator, can I reuse the plug. Meaning, cut the wires to length and insert the plug on the cut end. Or do I basically leave plug alone and cut out the slack and splice the wires together?
I don't own a soldering gun but I am assuming this is the best way to splice wires together?
Thanks for any input.
d1
defiant1 is offline
Old May 2nd, 2011, 08:45 AM
InfoJunkie
InfoJunkie's Avatar
Just loop the extra wire inside the convoluted tubing and hold together with electrical tape. Each wire you shorten do it in a different spot in the tubing. No need to cut.
InfoJunkie is offline
Old May 2nd, 2011, 09:13 AM
defiant1's Avatar
You're talking about that flexible black plastic tubing, correct?
defiant1 is offline
Old May 2nd, 2011, 09:43 AM
Lady72nRob71's Avatar
This will work for low current smaller gauge wires, but I would not do this for the large high current wires, as it can create excessive heating, esp. at the bends.
And yes, the convoluted tubing is the split, black stuff with the ridges. Big heat shrink tubing or that non-stick black tape wrap will work, too.
Lady72nRob71 is offline
Hawghead
July 18th, 2014 12:51 PM
ATrain1
Non-Olds Engines
June 29th, 2012 12:58 PM
rtpassini
Drivetrain/Differentials
June 11th, 2010 12:36 AM
344870M
August 21st, 2009 08:04 AM
a6m5zerosen
January 3rd, 2008 02:57 PM
Quick Reply: Best way to shorten wires...
