Cigarette lighter question
Old March 4th, 2011, 08:54 AM
Beob's Avatar
This is a 69 442 with new all new wiring and the power wire to the cigarette lighter is to big. I am using the orange wire with a round white plug on end. Is this the correct wire or is my lighter missing a piece?
Thanks, Rob
Beob is offline
Old March 4th, 2011, 09:19 AM
Should plug right onto the end.
Do you mean that the wire's too big, or the connector's too big?
MDchanic is offline
Old March 4th, 2011, 09:20 AM
Lady72nRob71's Avatar
Your lighter is fine. The wiring needs a smaller connector added to it. It is possible to remove it form your old harness and solder onto the new one.
I have heard of someone else running into this problem.
Lady72nRob71 is offline
Old March 4th, 2011, 09:46 AM
Beob's Avatar
The connecter on the wire is too big. I tried looking through the massive birds nest(my old harness) and couldnt find it, there is cut wires everywhere. Maybe I can find someone with an old harness that has that plug.
Thanks, Rob
Beob is offline
Old March 4th, 2011, 10:44 AM
Perhaps you should take this up with the vendor who sold you the repro harness? If they don't get feedback, they don't know there's a problem.
joe_padavano is offline
Old March 4th, 2011, 10:49 AM
69442C's Avatar
Rob, I had the same issue and had to use the original terminal and connector from an old harness. The ones on these reproduction harnesses are not correct. I'll look around to see if I have an old one but I don't think I do. If so, I'll let you know. The white plastic can be pushed off of the terminal and you can bend the brass terminal so it fits tighter. The plastic can then be slid back in place. Or, put a piece of shrink tube over the brass connector and shrink it down when you are happy with the fit and don't put the white plastic back into place. Or, maybe the plastic will slide over the heat shrink. The original connector is black and much smaller in diameter.
Brian
69442C is offline
Old March 5th, 2011, 01:45 PM
Beob's Avatar
Hi Brian, my original connector is gone, but dont go crazy looking for one. I will try to modify mine as you said.
Thanks, Rob
Beob is offline
brown7373
June 30th, 2016 07:42 PM
WHIPOLDS
September 17th, 2012 09:05 AM
Phil Glass
October 25th, 2010 11:20 AM
tim72
August 5th, 2010 07:51 AM
Bunser
May 24th, 2010 05:47 PM
Quick Reply: Cigarette lighter question
