2 connections to IGN terminal?
Old July 24th, 2010, 01:23 PM
HouTXCutlass's Avatar
Hey,
Can the HEI and electric choke both be connected to the ignition terminal on the fuse panel? If not, what would the best remedy be? How many connections there are too many?
What can the BAT terminal in the fuse panel be used for? Is it a constant voltage?
Thanks,
Rob
HouTXCutlass is offline
Old July 24th, 2010, 08:49 PM
Just the facts...
BILL DEMMER's Avatar
imo, the best way to do these connections is to use a relay with the coil being driven by the ign terminal. the supply pole of the relay could be connected to the wiper or heater fuse OR the bat terminal(which is always hot, regardless of the ignition switch). i prefer the double redundancy method. i used another relay driven by the oil pressure idiot light that switches the power to the electric choke off when the oil light is on. that prevents the choke from heating if the car stalls unattended during warm-up. don't overlook proper gauging of these wires and proper fusing too. use a relay with a 30 amp capacity and continuous duty ability.
bill
BILL DEMMER is offline
Old July 26th, 2010, 06:09 AM
bill
The relay idea sounds good. But in the interim just to get her started, I ran the choke to the oil idiot light as it's not used because I have a mechanical oil pressure gauge. But after she started, the idiot light stayed on until I pulled the choke wire off. Is that a grounding issue?
Thanks,
Rob
Old July 26th, 2010, 07:33 AM
Blk71SX's Avatar
yes, you're grounding the idiot light thru the choke
I power the HEI by the IGN tap on the fuse block.
I power the electric choke by one of the wires that originally went to the TCS switch on the right side of the intake
Blk71SX is offline
Old July 26th, 2010, 09:04 AM
Just the facts...
and the choke will not function properly because the idiot light won't pass enough current to heat the choke. btw, the oil pressure switch is not rated for more current than a light bulb, about a 1/4 amp. the contacts may burn closed.
bill
Red Dawn
March 22nd, 2015 07:37 PM
Cman7713
July 29th, 2014 11:13 AM
Redog
23
June 13th, 2011 05:26 PM
mont1le
February 14th, 2010 07:24 PM
Quick Reply: 2 connections to IGN terminal?
