Blower motor SQUEAL!- 68 442
I have a '68 442 convertible with factory A/C.
The blower motor has an awful squeal at virtually all speeds.
I am assuming the motor will need replaced.
Does anyone know how difficult this replacement is and a recommendation for a vendor to supply the motor?
Thank you.
Jim
Thank you.
Jim
Thank you.
Jim
Thank you.
Jim
I would also suggest that if you go that far, you MIGHTASWELL replace the heater core at the same time, since it also requires the fender to come off (to access the bottom bolt on the box).
To prevent the clip nut from spinning, put a 1/2 inch box wrench (six point) on the nut first and if your arms are short on one end then have a helper operate the ratchet whilst you hold the wrench firmly to prevent spinning... of course this is on an original '68 clip nut...
