HELP with starter circuit wiring
Old September 10th, 2009, 10:49 AM
kingkong8808's Avatar
i took the starter out of my 76 cutlass and the wires were fried, so i replaced the starter and all the wires and hooked the battery back up and the wire from the stater to the firewall burnt up the moment i touched the ground. so if someone could plz send me a diagram or something like that or tell me what i did wrong i would be thankful
kingkong8808 is offline
Old September 10th, 2009, 10:55 AM
I'm not a 76 guy but someone will be along shortly, I'm sure.
FYI The classic definition of Crazy is doing the same thing over and over again and expecting different results. So don't do it again.
Hang in there we'll get ya fixed up.
Jamesbo is online now
Old September 10th, 2009, 12:08 PM
Past Administrator
Oldsguy's Avatar
moved thread to electrical forum.
Oldsguy is offline
Old September 10th, 2009, 12:55 PM
the motor is the 350 rocket and i have got three wires, i have got the wire running from the battery to the starter which is red, than i got red 12 gauge wire running from the starter to the firewall, and than i have a black 12 gauge running from the starter to i dont no where, and i cant remmber how to hook it back up
Old September 10th, 2009, 04:00 PM
Land Yacht Captain
66ninetyeightls's Avatar
There should be the power wire from the battery to the starter(LARGE). The signal wire to the starter solenoid from ignition switch & usually a second wire from the solenoid that supplies direct power to the coil during cranking.
66ninetyeightls is offline
1973olds98
September 8th, 2010 07:15 PM
venividivici53
October 15th, 2009 10:09 AM
1FSTLS1
May 11th, 2008 03:39 PM
DaLump
February 14th, 2008 06:25 PM
mcutlass1969
June 23rd, 2007 08:49 PM
Quick Reply: HELP with starter circuit wiring
