Tick tock tach wiring to repo unit | clarification needed
Old February 21st, 2019, 06:14 PM
Brians1's Avatar
Does the tach wire itself ground to the bottom of the unit ? I have a repo tick tock tach and I bought the tach wire from inline tube. I know it goes to the negative side of the coil, but on the tach side...2 wires, 1 is brown and it self explanatory but the coax one...bottom of the unit for ground?
Brian
Brians1 is offline
Old February 21st, 2019, 07:16 PM
Dave26's Avatar
Just screw the “braided” wire to the mounting “ear” that screws into the metal strap on the dash. Other end grounds to the coil mounting bracket.
Dave26 is offline
Old February 22nd, 2019, 06:15 AM
^^^THIS. The overbraid is just a shield for radio noise suppression. The tach itself grounds through the housing to the ground straps behind the plastic dash. I've connected a bunch of tachs with unshielded wire, and with resistor plugs there wasn't any radio noise anyway.
joe_padavano is online now
Old February 22nd, 2019, 06:30 AM
Brians1's Avatar
Thanks gents ! - I'm also not running the OEM radio, doing an aftermarket Single DIN. I will connect the ground strap to one of the closest ground straps of the dash
Brians1 is offline
1972 "U" code
March 29th, 2020 07:30 AM
rhett838
June 2nd, 2017 10:16 AM
Bee Saint Louis
June 14th, 2016 03:22 PM
poopeye
May 15th, 2015 07:48 PM
Magna86
May 18th, 2014 02:10 PM
Quick Reply: Tick tock tach wiring to repo unit | clarification needed
