Wiring guidance 69 442 convertible - ClassicOldsmobile.com
Go Back  ClassicOldsmobile.com > Repair & Restoration > Electrical
Wiring guidance 69 442 convertible >
Old January 12th, 2019, 05:23 PM
My engine harness is in rough shape after it has had at least 2 engine swaps in its lifetime. I swapped in a 69 455 from an 88. Eventually I will put in msd style ignition, but it currently has a rochester 4bbl and points. Can someone help me decide which one is the right one. In the year one catalog it has transistor, with gauges, without..what gauges?
fusick only lists 1 so that makes me wonder if it matters?
I really could use an education on it. And if you really want to teach me, how do address all the wiring needed for my swap from manual to auto?
bob
Rvsmith5 is offline
Old January 12th, 2019, 05:50 PM
Do you own a paperback copy of the Oldsmobile
Chassis Service Manual (CSM) Chassis Service Manual (CSM)
for your 1969 442? A continuance of this discussion would be difficult without your having the ability to address the wiring schematic contained w/in the CSM (which contains a plethora of information).
Vintage Chief is online now
Old January 12th, 2019, 06:20 PM
From your other thread regarding the carb fast idle cam I reckon you own the CSM - that's good. Since, while I haven't the experience on changing out wiring from manual>auto, I was simply setting the stage for where most of the information would be derived.
Old January 12th, 2019, 07:11 PM
If its a wiring harness you want, give these guys a shot.
http://www.wiringharness.com/
oldcutlass is online now
seeyah
September 16th, 2013 03:35 PM
lll442
August 17th, 2010 08:44 PM
nukesec1
September 28th, 2009 05:16 AM
68delta88oldskool
June 17th, 2009 12:26 PM
O's_Car
April 28th, 2009 04:03 PM
Quick Reply: Wiring guidance 69 442 convertible
Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
