Strange Electrical Situation Head Lamp - ClassicOldsmobile.com
Go Back  ClassicOldsmobile.com > Repair & Restoration > Electrical
Strange Electrical Situation Head Lamp >
Old December 31st, 2018, 05:23 PM
Frisbee_k9's Avatar
Hi,
I have a strange situation. When I turn on lights sometimes the Drivers side head light doesn’t come on until I press the high beam foot switch.I have to click high beam on and off quickly and some times it comes on and some times it doesn’t come on at all. Passenger side always comes on.
Any idea of what to check? Is it the socket on the head lamp loose?
1968 Olds 442
Thanks in advance.
Guy
Frisbee_k9 is offline
Old December 31st, 2018, 07:05 PM
The fact that the passenger side always works tells me the wiring is good. When you turn on the headlights, power leaves the headlight switch on a light blue wire going to the dimmer, it then leaves the dimmer switch on either a light green wire (high beam) or a tan wire (low beam) both wires go to the drivers side headlights first. Then both bulbs have wires that lead over to the passenger side. Both bullbs on both sides have their own grounds, leading to a common screw under each pair of bulbs.
i bet your going to find either a corroded terminal in the headligh bulb socket, or corroded electrical tabs on the bulbs themselves. Check the ground wires and screws. You can get replacement sockets in the Help or Dorman section of a parts store. Use a wire brush to clean the terminals of the bulbs. Once everything is clean, pack the terminals with dielectric grease to keep them from corroding in the future.
matt69olds is offline
Old December 31st, 2018, 07:47 PM
^^^This. Matt nailed it.
joe_padavano is offline
Old December 31st, 2018, 10:56 PM
Frisbee_k9's Avatar
Thank you Matt. I really appreciate your answer.
Guy
Cutlass9691
August 24th, 2017 09:30 AM
e.cast728
April 7th, 2014 05:14 AM
wgonzo64
October 11th, 2013 05:31 PM
jfb
Body work
August 4th, 2013 01:51 PM
kona0197
June 11th, 2011 06:38 PM
Quick Reply: Strange Electrical Situation Head Lamp
Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
