Ignition switch won't return to Lock 1970 Cutlass - ClassicOldsmobile.com
Go Back  ClassicOldsmobile.com > Repair & Restoration > Electrical
Ignition switch won't return to Lock 1970 Cutlass >
Old December 2nd, 2018, 07:06 PM
OLDSter Ralph's Avatar
I bought a 1970 Cutlass 455 auto with power steering. It has an aftermarket floor shifter The ignition won't return to LOCK position and key can't be removed.
What do I need to do to get it working ?
OLDSter Ralph is offline
Old December 2nd, 2018, 08:05 PM
If I had to guess, I would say the neutral safety switch.
72455 is offline
Old December 2nd, 2018, 08:41 PM
classicmuscle.442's Avatar
May still have the original rod in column that is stopping key from moving to off position.
classicmuscle.442 is offline
Old December 2nd, 2018, 08:46 PM
Watch the collar on the steering column where the column meets the dash, it should rotate as the shifter is moved into gear. Try to put it into park and then rotate the collar by hand a little farther in the direction it went going into park. Hold the collar in that position and see if you can turn the lock enough to remove the key. If it works it is probably a linkage adjustment.
If that doesn't work, loosen the ignition switch on top of the steering column and try the lock,
If loosening the ignition switch doesn't work it is probably the ignition lock cylinder or less likely and internal problem in the collar.
Good luck!!!
Sugar Bear is offline
Old December 3rd, 2018, 11:14 AM
I've got $10 that says whoever installed the aftermarket shifter did not reinstall the backdrive linkage. Grab the collar on the steering column where the shift lever would have been and twist it as far counterclockwise as it will go. Your key will likely work now. Unless the shifter has a self-contained backup light switch, I'll assume your backup lights don't work either.
joe_padavano is offline
Old December 3rd, 2018, 11:37 AM
I'm not taking that bet... don't like losing
olds 307 and 403
August 25th, 2016 08:26 AM
Hurst/Olds 73/74
August 11th, 2014 01:08 PM
randomarrival
December 22nd, 2012 01:28 PM
vmathy
May 31st, 2010 05:32 PM
68conv455
May 20th, 2008 03:03 PM
Quick Reply: Ignition switch won't return to Lock 1970 Cutlass
Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
