gauge pin repair - ClassicOldsmobile.com
gauge pin repair
Old November 28th, 2018, 01:06 AM
gauge pin repair
What are you guys using to repair the problematic pins on the gauges? I have a 69 442 I've seen 3 different sets of gauges, (finally found a tick tock tach) and in all 9 gauges at least 1 pin has been broken off. About half have been soldered at some point in their life but even the ones that have been soldered are very loose. It looks like it would be a tough solder and if it takes much of any movement they will come back off.
I went to the hardware store with plans to run a stainless bolt 3-48 through the backside of the hole where the pins used to be, tighten a nut down, and just use that bolt as a pin. It fits through the hold and is the exact size as the original pins in 3-48................ Then I realized stainless steel might have too much resistance. I'm not an electrical engineer but most of the gauges work on resistance so I thought it might throw my gauge off. I'm guessing there wouldn't be enough resistance to matter with as little current as it's carrying but the last thing I want to do is put my dash back on and take it back off again to fix my fix. They don't make 3-48 copper bolt, they do make a 4-40 aluminum bolt that might work if I drilled the holes just a little bit. Has anybody else tried this with success? I'm guessing most solder it but I would feel better about something a little more solid.
eou_edu is offline
Old November 28th, 2018, 07:21 AM
oldspackrat's Avatar
I have repaired MANY pins on these circuit boards while restoring them for several members on this site & others. Feel free to call me?
317-727-7041
Scott
oldspackrat is offline
Old November 28th, 2018, 01:02 PM
allyolds68's Avatar
You could also do this. You run a very small screw right through the back of the pins leaving the pins in place
allyolds68 is offline
Old November 28th, 2018, 01:48 PM
Stainless steel would be fine. The current required to operate the gauges is very low, and stainless steel is a good conductor. I canít remember what size screws I used to repair my circuit board, but they were stainless. I fixed them probably 6-7 years ago, still working flawlessly
matt69olds is offline
Old November 28th, 2018, 02:37 PM
Certified Fanatic
Yellowstatue's Avatar
Go to a hobby shop and get 2mm bolts if you want to go that route. Not too long a bolt though, 1/4 inch?.
Yellowstatue is offline
lemoldsnut
May 19th, 2018 05:06 PM
68442
November 2nd, 2016 02:04 PM
Globeguy
September 30th, 2016 09:11 PM
JMcB
May 4th, 2015 09:59 PM
ironlou399
Tech Editor's Desk
March 23rd, 2013 08:36 AM
Quick Reply: gauge pin repair
Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
