Electronic distributor
Old September 18th, 2018, 11:41 AM
Sharrie Singmaster's Avatar
Need to know the procedure for installing electronic distributor and that 350 rocket motor
Sharrie Singmaster is offline
Old September 18th, 2018, 11:45 AM
It all depends on which electronic distributor your installing. Can you give us some additional info like a make and part number?
oldcutlass is online now
Old September 18th, 2018, 12:23 PM
Distributor
Old September 18th, 2018, 12:24 PM
Distributor
Originally Posted by Sharrie Singmaster
It is a WPS electronic distributor part number DST1893
Old September 18th, 2018, 12:48 PM
So its an HEI. What year/model car?
Old September 18th, 2018, 01:08 PM
Distributor
yes. Coil built into distributor. 1972 cutlass
Old September 18th, 2018, 01:50 PM
All you need to do is take the 2 wires that fed the original points distributor, sperate the, cap them off individually and tape them to the original harness. Then run a 12ga wire from the IGN spade terminal in the fuse block to the HEI distributor BAT terminal on the distributor cap. If you have a tach, it connects to the terminal next to it. Wire spark plugs with #1 cylinder at TDC on the compression stroke, then set your timing to 16 BTDC to start. Hook your vac advance can to manifold vacuum, then set your idle and a/f mixture.
I use one of these connectors, they can be had at any performance parts supplier or possibly your local auto parts store:
https://www.summitracing.com/parts/acc-170072
Old September 20th, 2018, 11:20 AM
distributor
72 Olds 350 Rocket #1 cylinder at top dead center when HEI distribytor is installed where should rotor cap be aligned with?
I am asking these questions for my husband. Since you have so much knowledge on this car, do you have a number he could contact you at.
deaddds
February 18th, 2019 07:42 AM
brandon reynolds
March 30th, 2018 02:02 PM
tgilligan
March 16th, 2018 08:39 AM
OldsAl
February 24th, 2018 09:27 PM
Slate455
January 29th, 2018 11:25 AM
Quick Reply: Electronic distributor
