307 still not sparking
Old September 11th, 2018, 12:59 PM
Copper Nine Eight's Avatar
Im ready to throw the whole care away.
i have done all the possible test and change everything i can. Still not sparking.
Copper Nine Eight is offline
Old September 11th, 2018, 01:10 PM
'87 Delta 88 Royale
rustyroger's Avatar
Erm, you haven't tested everything or you would have found the problem. Run through everything you have done and no doubt someone on this forum will look with fresh eyes and spot something amiss. Ignition systems obey the laws of physics, if everything is in working order, properly connected and timed, then it will work.
Roger.
rustyroger is offline
Old September 11th, 2018, 01:54 PM
Roger.
i found the problem! Even though i got a new ignition module some months back. I bought another one and i got consistent spark!! I am relieved!
Old September 11th, 2018, 03:02 PM
deadeyejedi's Avatar
aah the new part gone bad trick ! seems to happen quite frequently .glad you figured it out
deadeyejedi is offline
Old September 11th, 2018, 05:24 PM
1970greensupreme's Avatar
Lots of HEI replacement parts are sub par. Hard to even get a decent cap/rotor with brass inserts never mind decent module/pickup or coil
1970greensupreme is offline
Copper Nine Eight
October 17th, 2017 05:43 AM
kandelino
December 20th, 2010 12:54 PM
Destructor
November 14th, 2010 10:50 AM
84delta88
December 6th, 2006 06:25 AM
monsterpuff
October 17th, 2006 02:56 AM
Quick Reply: 307 still not sparking
