Never wired a dash before
I got a dash from the salvage yard. I had to cut the wires from the dash lights and gauges to put in my 85 delta. If i use the same gauge wires, it should work, correct? This might sound like a dumb question so i apologize in advance. The only thing i have experience in wiring, are guitars.
Any help is appreciated! Thanks!
You said you cut wires to get the replacement out. I'm going out on a limb here and wondering if you have an existing dash in your Delta right now? If you do, I would strongly recommend you study how the wire connectors are routed and just install the replacement by undoing the clips and bolts that already exist and reinstall them on the replacement dash. It's going to be at least the same amount of work as what the alternative is, and the existing wires won't have been tampered with or possible faulty connections.
Now I have a question about this dash you got from the wreckers. Is it the dash pad, or the whole dash? The pad won't have a lot of clips with wires, but the dash frame will have clips and small 7 mm bolts holding them in place.
Ok, that explains a lot. You can't just hook up the wires and expect it to work. You'll need to change out the senders for coolant and oil to the proper ones for gauges. The ones that are on the block (307 4bbl, right?) will be idiot light senders and don't work with that gauge setup. I know because I did exactly the same thing with my 1983 Ninety Eight Regency Brougham. Unfortunately I don't have the 83 CSM anymore as it went with the car when I sold it. If you have one, verify the wiring and connections to this unit as sometimes it requires modification.
