From no gauges to having gauges
Old September 8th, 2018, 01:33 PM
Copper Nine Eight's Avatar
What would i need to do, to get this to work in my 85 delta 88? It didnt come with the extra gauges. I think this looks very cool. I have all of the wires.
Copper Nine Eight is offline
Old September 8th, 2018, 03:14 PM
You need the correct temp and oil pressure senders and just wire it up. Did you get the little filler piece that goes below the steering column?
joe_padavano is online now
Old September 8th, 2018, 05:44 PM
I will check RockAuto for the correct senders. And yes i got the filler piece. I cant wait to wire it up!
Old September 28th, 2018, 10:48 PM
mjrj's Avatar
An 85 will probably have the pigtail on the harness. I swapped those gauges into an '83 Delta 88 I had years ago and it had the connector. If not, it's not too hard to add the connector. I added it to my '77 Delta 88.
1st photo is the speedometer connector. The gauge package connector comes off this. I've removed the terminal with a small flat pick tool
2nd photo is the gauge connector pigtails inserted into the speedometer connector, not connected to the harness yet.
3rd photo wiring finished. The gauge setup I put in was from a '82-85 B/C car, so I had to cut a hole in the dash panel for the window switch.
mjrj is offline
Old November 6th, 2018, 01:18 PM
I just seen this. This is incredibly helpful!
rhett838
April 26th, 2020 06:06 PM
scottw32
September 1st, 2019 08:06 AM
JIM'S w30
June 12th, 2012 08:33 PM
rustyroger
December 26th, 2010 04:29 AM
425cutty
May 9th, 2010 01:02 PM
Quick Reply: From no gauges to having gauges
