1969 olds cutlass parasitic drain
Old September 8th, 2018, 11:34 AM
Dylan Taylor's Avatar
Okay guys so I have a 1969 olds cutlass we restored. When we got the car we wired something wronge because I'm getting a parasitic drain on the battery. When I take the wire off from the horn relay to the firewall the drain goes away but also the car won't start or turn on. We have a wire from the battery to the alternator and then a wire from the alternator to the horn relay. Anybody have any suggestions on what that wire feeds from the horn relay to the firewall and where it could possible be grounded at? It's a bigger wire. Thanks in advance!
Dylan Taylor is offline
Old September 8th, 2018, 03:13 PM
The horn relay pretty much feeds the whole rest of the car. Disconnecting that wire is like disconnecting the battery - it doesn't tell you where the short is. You need to pull fuses one at a time until the drain goes away.
joe_padavano is offline
Old September 8th, 2018, 03:43 PM
And if you pull every fuse and the draw is still there disconnect the red heavy alternator wire. If the draw is gone after disconnecting that wire you have a bad diode.
matt69olds is offline
Rustbucket2
September 3rd, 2018 02:17 PM
68Dreams
January 18th, 2014 06:46 PM
joepenoso
June 28th, 2013 01:11 PM
defiant1
May 31st, 2011 04:30 PM
ctrain22
September 16th, 2009 05:27 AM
Quick Reply: 1969 olds cutlass parasitic drain
