Dash wires
Old August 29th, 2018, 11:01 AM
Drsantos's Avatar
Dash wires
Found a few wire connections not plugged into anything. Does anyone know where they may connect. One is orange the others are gray all are just right of the radio
Drsantos is offline
Old August 29th, 2018, 11:42 AM
They are pigtails for options that your car apparently doesn't have. Orange is the 12V feed for the dome/courtesy light circuit. It also feeds the clock (which is probably what that plug is for). The gray wire is the illumination circuit for instrument lights. Again, that probably feeds the illumination bulb in the clock.
joe_padavano is offline
Old August 29th, 2018, 11:45 AM
Back when your 69 was new, it was easier for GM to produce generic wiring looms for each product line. Not like todays cars where each car has a unique wiring harness. You're certainly brave tackling the wiring behind the dash of a 69.
Allan R is offline
abrasv
July 17th, 2018 09:51 AM
kens69olds
June 26th, 2015 12:42 AM
tbristol
May 7th, 2014 07:11 PM
Olds luvr
April 18th, 2013 11:41 PM
timothypaul
June 12th, 2011 05:43 AM
Quick Reply: Dash wires
