Brake light
Brake light
Installed a new harness last night in a 68 Cutlass s. Have a new bulb. Left rear brake light doesn't work. Any idea? Could it be in the switch at the pedal?
Also, left turn signal does not work. Light on dash lights up. Going to check ground and bulb at core support. Any other ideas.
thanks for the help.
Have you measured or tested for voltage when the bake is depressed at the rear lamp socket? Does the tail light work when you turn on the headlights? If you have voltage and the tail light works the only thing it can be is the terminal inside the socket is not touching the bulb.
