Electric window issue
Old August 9th, 2018, 03:42 PM
abrasv's Avatar
69 Cutlass S convertible with e windows all of a sudden will not operate. Worked fine the other day and now nothing. Fuse is good but replaced it anyway.
Help with ideas please!
abrasv is offline
Old August 9th, 2018, 04:53 PM
Might be your relay is fried. All 4 don't work? Not likely all 4 motors quit at the same time.
Allan R is offline
Old August 9th, 2018, 04:58 PM
abrasv's Avatar
None of the 4 work. Where the heck is the relay?
abrasv is offline
Old August 9th, 2018, 05:14 PM
Follow the wire coming from the IGN connection (lowest one in the middle) on the fuse panel. It should take you up to the relay.
Allan R is offline
Old August 10th, 2018, 08:20 AM
Rocketbrian's Avatar
Same thing happened to mine. The relay is behind the drivers kick panel near the top. Two screws hold it in place.
Rocketbrian is offline
Old August 10th, 2018, 08:28 AM
abrasv's Avatar
Thanks all.
You know, it really helps if, when you are working under the dash redoing everything, that you plug the wiring connector for the relay back into the relay itself. DUH!!!
Really goes a long way to make things work again.
All is well.
abrasv is offline
Old August 10th, 2018, 08:48 AM
We've all been there. �� Glad it was easy.
Old August 10th, 2018, 10:06 AM
Glad to hear it all worked out for you. I had a problem with my blower; it wouldn't work on some speeds, and finally quit all together. I ordered a new blower resistor and then found out the resistor connector had come loose. Same issue - previous work under the dash, but by 'certified' radio installers. Oh well, now I have a spare resistor...
Allan R is offline
Old August 12th, 2018, 09:28 PM
cjsdad's Avatar
DAMN those guys! Were they MECP certified or just certified by the shop? Everyone makes mistakes, it's how well you recover from them that makes the difference.
cjsdad is offline
JC3Hawaii
May 26th, 2019 12:13 PM
rand5204
November 6th, 2017 09:02 AM
duke68delmont
September 14th, 2015 05:22 PM
setagus
May 10th, 2014 01:09 AM
jugdish
August 18th, 2011 09:57 AM
Quick Reply: Electric window issue
