Issue or Anomaly?
Old July 16th, 2018, 03:59 PM
mmitton's Avatar
Issue or Anomaly?
1970 Supreme convertible. If you turn on the headlights with the ignition in the off position the power windows will work the same as if the car was running. Anyone else ever try that?
mmitton is offline
Old July 16th, 2018, 07:43 PM
Maintained
scottv442's Avatar
sounds like the windows are hooked up to the same circuit as the undrhood light.
scottv442 is offline
Old July 16th, 2018, 08:06 PM
cherokeepeople's Avatar
haha.schlitzguzzler had a 68 toronado that had an issue like that,if i remember the pass side power window only worked with lights on,got his pass side door ashtray puked in one day as the guy in pass eat couldn't get the window down before he hurled!
cherokeepeople is offline
Old July 16th, 2018, 11:06 PM
Gary M's Avatar
Sounds like schlitzguzzler needs a sober friend or a bigger ash tray and you need to trace the circuit. That can't be right. Power windows are a high power circuit if I remember correctly. Good luck.
Gary M is offline
PM70
August 12th, 2017 02:54 PM
Olds luvr
March 19th, 2015 09:34 AM
slantflat
Non-Olds Engines
November 20th, 2012 12:00 PM
yeahbuddy
June 24th, 2010 02:22 AM
real442
March 8th, 2008 07:03 PM
Quick Reply: Issue or Anomaly?
