68 Cutlass - Gen Light On, Engine Run On...
Old July 13th, 2018, 05:51 PM
olds70supreme's Avatar
68 Cutlass, dash removed for restoration and conversion to aftermarket Rally Pack.
When key is on (engine not running), GEN light does not come on.
When engine is running, GEN light turns and stays on.
When key is turned off, engine keeps running.
With key off, pulling the tach (brown) wire from the HEI does nothing.
With key off, pulling the 12ga power wire shuts engine off.
With engine started back up, voltage regulator test (per 12-11 of Service Manual), voltage between regulator #2 terminal and ground = 6.7. Manual recommends replacement of regulator, BUT why does gen light not come on when key on and engine not running?
I'm an electrical novice and trying to understand this w/o throwing parts blindly.
Thanks.
olds70supreme is offline
Old July 15th, 2018, 05:58 AM
stellar's Avatar
Check fuses
stellar is offline
dave marki
June 5th, 2017 10:18 PM
kw62583
November 19th, 2015 08:17 AM
442Dave
May 1st, 2012 04:29 AM
rktw31
April 10th, 2012 05:14 PM
bccan
September 24th, 2011 05:29 AM
Quick Reply: 68 Cutlass - Gen Light On, Engine Run On...
