Horn problem
Old June 26th, 2018, 05:32 PM
Rjharp's Avatar
Horn problem
Hi guys. I think the answer is relay but I am not real good with this stuff so I ask. When I push the horn button the relay clicks. If I put a jumper wire from the positive battery post to the connector with the black wire the horns beep. Bad relay?
Rjharp is offline
Old June 26th, 2018, 07:18 PM
Yellowstatue's Avatar
There is a lot of corrosion on those contacts. Clean them well with a wire brush or sand paper and try again.
Yellowstatue is offline
Old June 27th, 2018, 02:48 AM
Rjharp's Avatar
Will do.
Rjharp is offline
Old June 27th, 2018, 10:21 AM
Rjharp's Avatar
A little sandpaper did the trick. Thanks.
Rjharp is offline
tdmvlm
December 30th, 2018 07:49 AM
Dylan Taylor
September 8th, 2018 03:43 PM
Rustbucket2
September 3rd, 2018 02:17 PM
budg
August 31st, 2017 03:29 PM
cbogartjr
August 6th, 2016 04:48 PM
Quick Reply: Horn problem
