Mini Starter Question
Old March 21st, 2018, 10:03 AM
tz6p06's Avatar
Hi
I have a 1978 Trans Am with a 403. I have the issue of heat soak and was looking at replacing the starter. I was wondering what mini starters people were using. I was looking at the Jegs Prostarter but wanted to see what others were using. My engine is stock with no modifications.
tz6p06 is offline
Old March 21st, 2018, 10:25 AM
Run to Rund's Avatar
RobbMc. Excellent fit and quality.
Run to Rund is offline
Old March 21st, 2018, 10:30 AM
HighwayStar 442's Avatar
Hi and welcome. Everybody has an opinion, my being.
"Powermaster" Made in USA. Have their XS Torque Starter. After 12 years, spins my high compression SBO 362 with ease. https://www.summitracing.com/parts/p...ake/oldsmobile
Read the reviews. Adjust with shims that come with it. Uses loctite on the bolts. Powerful little motor and after 10 years and moving from the north to the south. The bolts started to backout.
Hard to see under the Thermo-Tec Starter Heat Shield. My headers get mad hot.
HighwayStar 442 is offline
Old March 21st, 2018, 03:37 PM
tz6p06's Avatar
Thanks for responding. I looked at the RobbMC 3004 starter.
The one by Jegs looks just like the Powermaster and the specs are the same. I wonder if they make it for Jegs?
tz6p06 is offline
Old March 21st, 2018, 03:56 PM
I looked at both. And looks like a little difference. In the clocking and bolt block. Maximum Recommended Compression Ratio 18.0:1 for powermaster. 12.5:1 Compression for jegs. And $56 cheaper. Not the same I guess.
All I know the powermster spins my engine like crazy! And working for 12+ years. Sometimes you get what you play for. Hope that helps.
Old March 21st, 2018, 04:23 PM
tz6p06's Avatar
True, technically you're right they're not the same but for my stock 8:1 either should work fine. Probably look at the powermaster, might be easier to get.
tz6p06 is offline
Old March 21st, 2018, 04:55 PM
Always loved the Shaker on your Trans Am. The best Olds had was the 1968 H/O two mail boxes on the hood. What color is your car? Have any pictures?
Old March 21st, 2018, 05:30 PM
tz6p06's Avatar
Here are some pictures, I hope they get loaded correctly.
tz6p06 is offline
Old March 21st, 2018, 05:40 PM
She is clean. love the blue color!
Old March 21st, 2018, 05:44 PM
tz6p06's Avatar
One year only color, I love it too
tz6p06 is offline
Old March 21st, 2018, 06:16 PM
Nice Fire Chicken.
oldcutlass is online now
Old March 21st, 2018, 06:40 PM
Screening Chicken
Oldsmaniac
June 4th, 2013 01:16 PM
STLCRZY
December 17th, 2012 12:47 PM
don_69sbo
August 21st, 2011 06:14 PM
rhaberm
April 19th, 2011 09:58 AM
scott71
March 22nd, 2011 12:19 PM
Quick Reply: Mini Starter Question
