LED gauge bulb fit?
LED gauge bulb fit?
Found many posts here about converting to LED, but nothing specific about the fit issues I've seen elsewhere online. Apparently some of the LED replacements are slightly bigger than the originals and won't quite fit in the housing - slightly too long, I think. Has anyone upgraded 71 Cutlass gauge lights to LED without issue, and if so, do you remember the manufacturer of the LEDs?
Typically it's not the 194 bulbs that are a fitment issue. The 1157's however most often won't fit properly in the OEM sockets. One note on the 194's, they are polarity sensitive, so if you install one and it doesn't light, rotate the socket 180 degrees and it should work.
here's a current ebay example - very easy search - https://www.ebay.com/itm/10x-12V-T10...kAAOSw8iZanFxE
I don't really see any coverage difference across the gauge faces, just the difference in terms of the bright white lighting v. the normal backlighting color you get from the regular lamps.
I like them but I can see where others might find them a bit stark in contrast to the warmer tone of a regular bulb.
Aceshigh
February 18th, 2012 07:00 AM
