What color are the neutral safety switch wires??
Old March 6th, 2018, 09:52 AM
Toocool's Avatar
Ran into another electrical issue. Yesterday I put a radio in the dash, now the car wont start, not even a click. The headlights don't dim when turning the key, the battery is fully charged. The only thing I can figure is I must have accidently unhooked the neutral safety switch. So, what color are the wires for the neutral safety switch??
BTW, I ordered a service manual for the car but don't have it yet.
Where do the wires plug in??
67 Vista Cruiser.
Toocool is offline
Old March 6th, 2018, 10:01 AM
2blu442's Avatar
The neutral safety switch is at the bottom of the steering column, near the firewall inside the passenger compartment. Here's a picture from the side on a 1967 Cutlass. It doesn't show up on the photo, but the purple wires also plug into the switch. John
2blu442 is offline
Old March 6th, 2018, 10:21 AM
Frank Ignachuck
ignachuck's Avatar
We know you bought the Service Manual yesterday.
You really should wait until it arrives before attempting some of these projects.
It will make your life much easier.
ignachuck is offline
Old March 6th, 2018, 12:22 PM
Toocool's Avatar
Anytime I get a new project I jump in with both feet
Toocool is offline
Old March 6th, 2018, 01:09 PM
Frank Ignachuck
ignachuck's Avatar
Yep, I know. I have all the service manuals and parts books for my car, and a lot of times I go to them AFTER I can't figure it out......
Old March 6th, 2018, 02:09 PM
Check the NSS, I bet that's your issue.
oldcutlass is offline
Old March 6th, 2018, 02:12 PM
jaunty75's Avatar
Change the station.
jaunty75 is offline
Old March 6th, 2018, 02:39 PM
matt68F-85's Avatar
Try holding the shift lever all the way up in park against the stop.
matt68F-85 is offline
Old March 6th, 2018, 08:56 PM
cjsdad's Avatar
Did you try starting in neutral as well as park? There is nothing around the radio that would impact the starter or the neutral safety switch. If you haven't moved the car since the radio install it's possible you leaned against the shift lever hard enough to move the linkage out of the "safety" range of the switch. Keep your foot on the brake pedal and move the shifter through its range of motion and see if the starter engages.
cjsdad is offline
Old March 7th, 2018, 03:48 AM
Toocool's Avatar
I got it, I had knocked the neutral safety switch loose. it apparently is loose, if I touch it wont start, have to wiggle it to get it back in place. Another task to do.
Toocool is offline
Old March 7th, 2018, 05:45 AM
cjsdad's Avatar
Old cars are not for wimps. They require attention just like most good things in life. The more time and love you put into it, the more enjoyment and satisfaction you will get out of it.
cjsdad is offline
Old March 13th, 2018, 05:57 AM
jRoofgunner's Avatar
I got one of those big wiring diagrams and it is colored. I'm not in the shop but me thinks it's Classic Autowire. I put it in a frame. It goes on the wall, in a place where I can take it on and off to refer to it. This is the only way to go. It's big. And yes those wires are purple and they are purple in the console also. Go get 'em!!!
BTW: Petronix supplied info with their flame thrower coil that tells you to put two diodes in line from the coil to the tach. I got the correct ones, installed them and the tach(original Olds tach on the console) does work and it is accurate; verified by a laser tach off of the balancer.
jRoofgunner is offline
Old March 13th, 2018, 07:01 AM
Frank Ignachuck
ignachuck's Avatar
I got my laminated wiring diagram from www.classiccarwiring.com
Very handy, and they make great placemats!
Old March 13th, 2018, 11:35 AM
I 'm in the shop and mine is from Classiccarwiring also.
Old March 13th, 2018, 01:25 PM
Toocool's Avatar
Thumbs up
I just ordered one.
Toocool is offline
onofre442
September 5th, 2017 08:33 AM
Charly9g
November 6th, 2016 05:10 PM
oldspackrat
November 17th, 2014 06:31 AM
footbrake
June 12th, 2006 06:10 PM
oldsnut7098
August 10th, 2003 10:06 PM
Quick Reply: What color are the neutral safety switch wires??
