anything stronger than factory blower motor?
Old February 19th, 2018, 06:44 AM
rick442's Avatar
I'd like to find a blower motor stronger than the factory. Here in GA, it would be nice a to have. ('71 442)
thanks
rick442 is offline
Old February 19th, 2018, 07:34 AM
mrolds69's Avatar
If you need a blower motor stronger than factory, there's probably something wrong with your motor or system. Hot or cold air, the motors in these cars should be plenty.
mrolds69 is offline
Old February 19th, 2018, 03:29 PM
mrolds69's Avatar
I had another thought. These cars are riddled with duct work and hoses behind the dash. Are you sure everything is there and hooked up right?
mrolds69 is offline
Old February 19th, 2018, 04:06 PM
Rocketbrian's Avatar
I replaced the blower motor in my 71 442 with an aftermarket unit from Car Quest and although it was for a non A/C application, I noticed right away it was more powerful than the factory unit. It is made by Four Seasons, part number 35587. I don't know if there is a different fan motor for an air car. Might be worth an inquiry.
Rocketbrian is offline
Old February 20th, 2018, 11:50 AM
Yellowstatue's Avatar
The squirrel cage might be larger for an A/C car. Same diameter but taller.
Yellowstatue is offline
Old February 21st, 2018, 10:23 AM
rick442's Avatar
Thanks guys,
Everything is hooked as factory and works. I just want a blaster for a fan.
And keep the Queen cool as possible.
rick442 is offline
BLACKCADDY
June 13th, 2011 06:02 PM
redvettemike
September 6th, 2010 07:06 PM
Texas67olds
November 1st, 2009 12:59 PM
Redog
November 30th, 2007 06:22 AM
Luckyme1870
Aurora
July 26th, 2007 05:05 AM
Quick Reply: anything stronger than factory blower motor?
