Distributor shaft
Old November 14th, 2017, 07:41 AM
Copper Nine Eight's Avatar
Distributor shaft
When putting a distributor back together, do i have to lube the shaft with engine oil? I ask because when i disassembled it, there was oil on it.
Thanks guys
Copper Nine Eight is offline
Old November 14th, 2017, 08:26 AM
Tedd Thompson's Avatar
I'm not sure of what engine/year we are talking about here but on most Oldsmobile's engines at the rear there is a oil galley plug that has a small hole that allows oil to lubricate the distributor gear . I think this is what you are seeing. If the engine hasn't been run for a long time or is just been rebuilt you need to lubricate that gear and shaft so it won't run dry till the oil pressure comes up..... Tedd
Tedd Thompson is offline
Old November 14th, 2017, 08:30 AM
Are you reassembling a distributor or merely inserting it back into the engine? For reassembly, the shaft should be lubricated with grease. For inserting into the block, do what Tedd said.
Fun71 is online now
Old November 14th, 2017, 08:46 AM
Reassembly. I had to replace the pickup coil.
Old November 14th, 2017, 08:47 AM
ok great. Thanks Tedd!
Old November 14th, 2017, 11:45 AM
Be sure to clean out any hardened grease that may be in the housing where the shaft goes. Mine had quite a bit that I had to nearly chisel out.
Fun71 is online now
70convert
Drivetrain/Differentials
March 7th, 2019 02:12 PM
EightyEightCut
January 19th, 2014 08:35 PM
hullinger
December 12th, 2012 12:18 PM
Frogge467
March 24th, 2012 11:09 PM
64 CUTLASS KEN
November 22nd, 2010 05:17 PM
Quick Reply: Distributor shaft
