AC to Non-AC Alternator Wiring
I'm hoping someone here might be able to help me with this. I have a 1969 Cutlass S that was originally equipped with AC. Some time ago I replaced the original 350 with a 1969 455 from an AC car (so it had all the necessary brackets I needed).
I have removed all the related components in the engine compartment (compressor, condenser, evaporator). With the compressor removed, all the remaining engine-mounted accessories (power steering pump and alternator) are located on the driver side of the engine, leaving the pass-side empty and (at least, visually) unbalanced.
I have a spare 400 out of a '68 non-AC 4-4-2. It has all the brackets and hardware I would need to mount my alternator on the passenger-side of my engine, so it would look correct for a non-AC Cutlass.
My question is about the electrical wiring. I want this to look correct. Does anyone make/sell the proper wiring and/or harness that would be used on a non-AC '69 4-4-2? Is there more to this than I am imagining? I can't be the first person who wanted to do the same thing. If anyone here has done this conversion I would love to hear any insights or advice from you.
Thanks very much,
Uncle Hulka
Thanks very much,
Uncle Hulka
There is far LESS to this than you are imagining. Simply route the alternator wires to the other side of the engine. Extend as required. Problem solved.
Yes, someone has done this before. That would be the factory, on every single non-A/C car built.
Thanks for the reply, Joe.
The wires going to my alternator are extremely short and would not reach anywhere near to the non-AC alternator location. I understand how to extend wires. As there is some significant current involved, I was hoping to use a factory-style harness made specifically for this purpose. If no one makes such an item, I'll extend as needed. I just want it to look like the factory did it, that's all.
Once again, Joe, you go right to the crux of the issue. I didn't (but should've) realize that the alternator harness was integral to the engine wiring harness. That was my hang-up. Replacing the entire harness is not an option. I'll extend the wires (or course using similar gage wire) and make it look as factory correct as possible.
Thanks, Joe!
Thanks, Joe!
70 w-30
February 9th, 2016 06:05 PM
e.cast728
April 7th, 2014 04:14 AM
