No Tail lights etc
No Tail lights etc
All lights were working great.
On the way home from a show, lost the dash lights & tail lights.
All front lights & rear brake/turn/hazards still work.
All the fuses are good.
Any ideas?
Thanks in advance
Any ideas?
Thanks in advance
Yeah, troubleshoot the problem with a test light.
Start by looking at the wiring diagram in the CSM. The only things in common with these circuits are the 20 A TAIL fuse, the wire from the fuse box to the headlight switch, and the headlight switch itself. Use the test light to check for power on both sides of that fuse. If power is good, check the terminal where it goes into the headlight switch. If that's good, it's probably the switch itself.
FYI, the only other item on that fuse is the underhood light. If your car doesn't have one, verify that the pigtail coming out of the firewall didn't bounce around and ground out.
Also, you didn't mention it, but I ASSUME there is no aftermarket wiring connected to this circuit.
Brandon_T
April 19th, 2017 08:45 PM
Oldssupreme
April 3rd, 2015 08:36 PM
oldstuff
September 13th, 2011 08:03 AM
