67 Toro- need turn signal switch
This car has tilt/tele + no cornering lights. From my web search I need gm 7805676 D6230. My original switch had the cornering light wire ribbon but wasn't connected to anything under the dash- so not sure if the replacement switch matters whether it has cornering lights or not. Rock auto sells switches but none for tilt/tele. Does anybody know the difference between the tilt/tele switch and the none tilt/tele switch? Or any other switch that would work? My original switch is blue. Thanks Steve
Thanks Joe. I'll keep looking. I was wondering if a non- T&T switch could be modified to work somehow- not sure. Like if the molded plastic was the same and I could re-arrange the wires to suit. Thanks Steve
I’m having the same issue finding the part number. The 66-69 book shows for a 67 98 exc corn lamp or tilt, corn lamp exc tilt, exc tilt, or tilt wh exc f85. But no tilt wh and corn lamp. I assume to use the 7805676 switch which is listed for tilt but doesn’t exclude corn lamp. Is this correct?
I bought one of these about 20 years ago. Was hard to find then. Seems they are made of unobtainium...
