Correct windshield atenna ?
Old September 2nd, 2017, 07:31 AM
ben442's Avatar
68 442,
Is this the right one?
The wire off the windshield is that short, won't extend any farther, can the connection float or should it be grounded?
Thanks...
ben442 is offline
Old September 2nd, 2017, 07:36 AM
mrolds69's Avatar
It looks about right, it grounds through antenna cable screws.
mrolds69 is offline
Old September 2nd, 2017, 07:38 AM
Originally Posted by ben442
68 442,
Thanks...
You do realize that 68s didn't use the windshield antenna, right? Having said that, I've actually done this swap on a 68. You need to cut the hole in the cowl panel below the antenna connector where that input cable bolts down. 1970-72 cars had it from the factory. Yes, the coax cable connector wants to be grounded. The parts you have are correct.
joe_padavano is online now
Old September 2nd, 2017, 07:44 AM
ben442's Avatar
Thanks, Ben
ben442 is offline
47 Convertible
July 1st, 2017 11:24 AM
fahaka
May 29th, 2007 10:15 AM
woody
December 30th, 2006 07:40 PM
72drptop
October 9th, 2006 04:50 PM
Quick Reply: Correct windshield atenna ?
