Electrical shortage
Old August 25th, 2017, 08:20 AM
Dibabyboyde7's Avatar
Electrical shortage
on my 63 olds 98 the horn wiper and fan does not work. But it work if it wired straight. What does this sounds like
Dibabyboyde7 is offline
Old August 25th, 2017, 08:34 AM
First, did you check your fuses? If they are all good then it's time to use your multi-meter.
Check for 12V at your horn button, wiper switch and fan switch. If you read 12V then there is a problem with the circuit after the button/switch. If you don't have 12V then there's a problem before the button/switch.
Olds64 is online now
Old August 25th, 2017, 08:39 AM
You won't find power at the horn button. The button switches the GROUND, not the power.
To the OP:
What exactly did you hot wire to get these items to work? This is pretty basic stuff. If the accessory is working, either the power source or the switch is bad, or the wiring between them is bad. Trace it back with a test light until you find the problem.
joe_padavano is offline
Old August 25th, 2017, 08:42 AM
Oops...
jf857
April 28th, 2006 07:24 AM
BOB W M
April 7th, 2006 06:30 PM
PetChemMan
December 15th, 2005 04:15 PM
86in
February 9th, 2005 09:49 AM
NV WIDOW
September 1st, 2004 04:34 AM
Quick Reply: Electrical shortage
