72 Cutlass Marker light correct operation question
Hi All,
When i pull my headlamp switch on to the first position (the one where only the marker lights come on and not the headlamps), one of my front bumper lights (in red below) turns on, and one of them does not.
1) Are these lights supposed to come on in the first position?
2) Is it possible that i just have a bad ground, i've played around with the socket, connector and have had no luck so far.
Thanks for the help,
Tony
Tony
Yes, I agree with Eric.
An interesting side note Tony. When the park or headlights are on the front side marker lights will alternate with the front headlights. An early feature to creating the side flash indicator.
Also put some dialetric grease in the socket. It will help prevent corrosion and improve conductivity.
A thought - if you put on that signal light, does the front bulb flash or do you get a solid green indication on the dash? Usually a burnt out bulb will cause a no flash condition.
Alright so i made some diagnostic progress last night!
Here shows a picture of what happens when i pull the switch into the first position:
Here is a picture that shows what happens when i hit the left turn signal, the marker light on my fender and the driver side bumper light alternate and flash (i think as they should?).
NOW, what i did is disconnected the little connector that the light connects to and i tested to see if it is hot when i turn the headlamp switch to the first position. YES, i have voltage, so this leads me to think there must be an issue with the light housing.
I tested the continuity between the connectors and the light switch (with the two metal buttons that pushes in) and both are hot.
Here is the kicker, i tried to get a connection between the headlamp housing and the lightbulb ground and BAM, nothing. I couldn't get a good ground connection (See below).
Now, how the heck do i take this headlamp socket out and clean the contacts, the whole housing could probably use a bit of a refresh..
Tony, you haven't grounded the housing to anything. I'd bet your problem is simply a faulty bulb after reading what you did. Put in a brand new 1157 A and see what happens. If you have voltage to both contacts, that tends to indicate the bulb is the problem. You might also try lifting the contacts in the socket just a bit to ensure they're contacting both nibs in the bottom of the bulb.
Make sure the spring loaded contact move in and out easily. Clean the area where the screw contacts the housing that mounts the housing to the bumper. Since all the other lights work your ground is good. Then change the bulb.
Is it possible to take the little spring loaded part out and clean it? I'm going to try the WD-40 thing as well as what Eric suggested above for piece of mind.
Yes, make sure of this! It's a very common problem with the sockets on front and rear lights. The grease gets old and hard, or the springs corrode and may even fall apart. The result is the wire terminals not making contact with the bulb base. While you're cleaning the socket, try pushing the wire from the rear so it and the terminal come forward a bit. This allows you to clean the gunk off the part of the insulation that moves in the socket and may help it move more freely when you put it back together.
