replacing turn signal collar on 72 cutlass
Old August 12th, 2017, 01:31 PM
Chris
Oldssupreme's Avatar
Hi everyone! My turn signal lever on my standard automatic trans column has always been very loose and sloppy and now that I have the column out of the car I can peek in with a flashlight and it appears that the plastic collar is cracked. I have another that came from a low mileage parts car. Can anyone point me to a thread that explains how to get the column apart and replace this collar and anything else I should replace along with it? Thanks!
Chris
Oldssupreme is offline
Old August 12th, 2017, 02:01 PM
Its pretty self explanatory once you get the steering wheel off.
oldcutlass is offline
Old August 12th, 2017, 02:12 PM
Chris
Eric, I have a steering wheel off already but when I tried to remove the screws underneath the steering wheel and Horn and contacts and all nothing really happened lol.
Old August 12th, 2017, 02:35 PM
There should be a parts breakdown in you manual. It should look similar to this.
http://www.justanswer.com/uploads/dg..._87_column.jpg
Old August 12th, 2017, 04:03 PM
Chris
Thank you Eric. That's the CSM or the AM?
Old August 12th, 2017, 05:13 PM
Chris, that's from the parts manual
Allan R is offline
Old August 12th, 2017, 05:46 PM
Rustbucket2's Avatar
https://classicoldsmobile.com/forums...rn-issues.html
pics on #19
Rustbucket2 is offline
67442nut
April 4th, 2016 11:55 AM
costpenn
June 24th, 2015 10:38 PM
Mr Nick
May 27th, 2015 11:06 AM
Jayycobb
Drivetrain/Differentials
December 6th, 2011 07:27 AM
richeyb
October 11th, 2010 09:55 AM
Quick Reply: replacing turn signal collar on 72 cutlass
