Convertible Power Window Motor
My convertible power windows are very sluggish going up. How do I know when they are done and I need to replace them? Is there a way to rebuild them? Jim
Thanks Blakes. It's actually the rear windows so I'll see about what I can lube there. I'll have to figure out the equivalent 2017 lube from what the 1969 service manual says. It's always tough trying to figure those out.
Use silicone grease only. Any petroleum based grease will eventually attach the plastic rollers. This may solve the problem, as the factory grease dries out over time, however it can also be do to worn brushes in the motor.
I doubt the motors have enough run in time to wear the brushes significantly. They're only on for short periods of time. I would do what others have suggested first. Joe makes a good point about the grease and avoiding petroleum based products.
Power window motor refresh
I think you'll get more effective results from cleaning & lubricating the guides & rollers. However, it wouldn't hurt to clean the connector contacts at the motors and switches as any resistance at these points will reduce the effective voltage at the motors causing them to run a bit slower.
Thanks to all of your feedback, I was able to reuse the old motors. The 50 year old grease and surface rust on the tracks, cams and other parts was the problem. I cleaned everything with wire brush and wheel and brake cleaner. The motors moved the windows up like they were brand new. I'll have dismantle again to reapply silicone grease.
lemoldsnut
February 20th, 2017 03:06 PM
