License Plate bulb socket
The socket cannot be fixed a ground issue. The bulb is 97 or 1155
Where can I get a socket I am not to bright I guess. Many sites have a push in bulb socket. This should be a push in and twist bulb.
I thought this would be simple to find
The socket is swaged into the housing. You won't find a specific replacement because it is not replaceable by itself. You will either need to machine out the old socket and adapt something else, find a good license plate light assembly, or do what I did on my 62 Olds and just replace the whole thing with an LED license plate light.
craftsmen22
February 4th, 2015 06:42 PM
