1972 cutlass wiring question
Hi. This may have been covered in another thread but I could not find it. I am restoring my 72 cutlass supreme, the wiring under the dash was butchered. I have figured out most of it except 2 purple wires coming steering column by the neutral safety switch. Also my stock radio was missing. I found a working one but am wondering if I have to hook up a rear speaker. I have seen threads saying not to operate without a 10 ohm speaker but do I need to run both? Thanks.
Okay. I will have to look again, I was sure there were no connections left available on the switch. Maybe an incorrect switch or someone rewired it. I will check for power and then trace the other wires and check the back up lights. When I got the car safety switch was disabled, the car would start in gear, not ideal. Thanks.
they removed the back drive assembly and hacked up some wiring under the dash, a few connectors and wires going nowhere. I have the back drive put back. I think the seat belt buzzer is missing as well. oh the fun.
ros6872
June 13th, 2014 09:18 AM
oldzy
September 10th, 2009 05:23 AM
