1970 Cutlass need picture of harness routing
Putting a 1970 Cutlass convertible back together after many years of being apart. Dash is back in with most things connected and working, but might not have the harness routed the same way it was from the factory. Wondering if anyone has pictures to share before they installed their dash. I have assembly diagrams, but kindof hard to visualize. Also, I see there is a heavy ground lug sticking out of the harness. Hoping someone knows where that gets connected, and also any other dash ground connections. I know convertibles and coupes are not exactly the same, but comments and pictures from both might be helpful. Thanks.
Thanks but I have the assembly manual. I don't think the diagrams are that great, but I guess I'll look a little closer. Did you understand my question about the heavy ground lug sticking out of the dash harness? do you know where it's supposed to connect? I could just land it somewhere on the inside metal surface of the dash, but was looking for someone to be specific if possible.
perro
September 4th, 2007 11:52 PM
