Engine Compartment Wiring Problem
I was wondering if anyone knew what a single plug double brown wire would be for on the engine harness. I have a 1971 442 with the rally pad setup. The double brown wire single plug is on the harness that runs to the temp and oil sensors. I purchased the harness from American auto wire but they have no clue what I'm talking about. Can anyone lend some advice?
My guess is the under hood lamp.
This is from a 1970, but I suspect that they are very close.
I found out today from a fellow Oldsmobile genius that this connector is used for the rear defroster. Thanks so much for the help. Now onto the under dash wiring harness. Please pray for patience for me😬😬😬😬
Rocketguy
November 24th, 2014 12:05 PM
dallasite21
June 19th, 2010 07:42 PM
dharlett
October 8th, 2008 06:08 PM
